Hello! I have a question about metal weights- I believe silver is
heavier then brass- and if that is so, how much heavier? I made a
model in brass to cast on my lathe (wax kept breaking- I had to use
metal) and I was trying to figure out how heavy my final piece will
be (they are earrings). Also I need to do a little soldering. I was
going to sold a silver jump ring on to the brass piece. I don’t care
if the metal discolors because it is a model for a mold. But does
silver have a higher melting rate then brass? And do you think I can
use silver solder? I never soldered brass before.
Thanks in advance!
dede
