Lori
Get HARD charcoal blocks. You must have used the regular type, and
they do keep burning. The hard and you need to make sure it is hard
will not burn like that. I’ve found most charcoal blocks sold are
just one type, and it is the regular not hard. I know Rio and Otto
Frei both sell hard charcoal. I love my charcoal blocks. If they get
a bit irregular on the surface, I take outside to the back and use
the concrete walkway as a sanding surface. It sands off the surface
and I’m good to go.
As for the solderite board, again get the hard not the soft. You
won’t be burning holes in it. I used one 12x12 size board for nearly
6 years doing thousands, yes thousands of copper ornaments on it each
year. I finally gave it the heave ho. But do not try to wash off flux
and the like on it.
Brush with a stiff brush if you are worried, again do it gently.
You will have problems using communal supplies. As you go along, you
need to get your own things to insure no contamination. I’ve never
worried about finger prints on solder, and have never had a problem.
In fact in all my classes way back in the day, I was never taught a
thing about fingerprints on solder.
I use the white paste flux. If it gets a bit hard, I just make a
well and put some water in it. After a bit of a stir, I have a nice
soft flux again. I know many on here have a different method to take
care of their hard paste solder, but mine never gets that
hard.Communal soldering paste has the biggest problem of getting
dirty. No way around it with many people using the same flux. Best to
just buy your own supply. I’ve laso used the liquid flux. They are
both fine, it is just what you get use to using, and for me what I’m
doing that I will grab one over the other.
As to your bezel type, I have different pictures in my mind of what
you are doing. It might be helpful if you posted a picture. It sounds
like something you might need to encase part of it in one of the
putties that protect it from heat. I don’t know, but that is what I’m
picturing beyond a simple wire as the base. It also might help to use
a soldering pan with grain or lump stones in it to help support and
protect delicate parts. So a picture is valuable in this instance.
Aggie
