Materials: silver (PMC Pro)
Dimensions: 18mm height and 23mm in diameter at its largest point.
The vessel was based on the fractal nature of a seashell; this shape was chosen as organic forms are notoriously difficult to recreate. The organic theme is also analogous with the rapid prototyping process used, as the seashell is literally ‘grown’ in the machine. The theme was further reflected by exaggerating the texture produced by the manufacturing process, which is reminiscent of seashells.
The addition of the plant conceptually closes the cycle; from the inspiration of nature itself through inorganic construction to end up as a vessel containing life.
Photo credit: Esteban Schunemann
Esteban Schunemann
Brunel Univeristy. London, UK
As an industrial designer and researcher at Brunel University, I am investigating the deposition of paste-like materials for Rapid Prototyping in a number of design contexts, including medical, craft, product and open design.
I draw my inspiration from repetitive patterns found in nature such as fractals and hyperbolic tessellations. These patterns help me device build strategies and geometries which are then fed back into the design process. The creation of a piece is not as simple as pressing print, depending on the application and geometry in mind, the process requires creative solutions to make it possible to build what is desired.
The process developed for research enables the user to build with virtually any material ranging from soft rubbers to metals. The materials are built up layer by layer in a bottom up configuration; this gives the finished pieces a stepped/layered texture.
