How common is this practice?
That, or some variation, is how most commercially made cast jewelry
is made. If the original model is carved in wax (increasingly common
these days, by use of CAD CAM mills or RP machines, you still then
end up with a cast metal piece, which often is done in silver, but
which may also be brass, nickel silver (uncommon for cast models,
more common for fabricated ones) or even pewter (again, more common
for fabricated models). That’s then finished to desired degree, and
molded.
For high volume manufacturers, there’s a whole other step. The
original model is made or cast from a wax, and molded. Then a series
of castings made from that first mold are sized to the range of sizes
the ring will be sold in (sizes of these are adjusted for various
shrinkage factors…), and these second generation castings are
themselves molded, sometimes many times, to produce the final
production molds. This way, the original single model ends up as the
model for a whole range of finger sizes, and depending on production
needs, each size may be represented by many copies of that mold from
the second generation models.
Many, if not most, jewelers and smaller scale manufactures do it
with just the single mold from the first model, sizing the resulting
wax models as needed.
of course, then there’s the other way, which is simply to initially
make the desired ring in the desired final metal, in this case,
platinum. With platinum, since seams in a shank or plain band can be
truly welded, instead of just soldered, it’s quite possible and
straight forward to produce a plain wedding band that does not have a
seam, since after welding, perhaps a bit of forging, and
re-annealing, the metal can be quite uniform in structure with no
discontinuity where it was welded… The main advantages of doing it
in silver, and molding and then casting the piece is that there may
be less waste produced (though a plain wedding ring need not produce
a lot of waste to fabricate), and then you have the mold in case you
ever need to make another. The fabricated ring, however, will often
be better metal, since forged and rolled and worked metal, especially
platinum, benefits greatly from this working, giving you a denser and
less porous (two ways to say the same thing) metal, with finer more
uniform structure. It may, as a result, be a ring with a much
greater durability and expected life span than the cast equivalent.
Peter
