Hi,
Since I cannot afford to buy gravers to attempt what I want to do, I
though I would have to make some. I know I will need at least a few
for shaping spaces, not necessarily to become an engraver.
These are my initial attempts, as an exercise.
http://www.ganoksin.com/ftp/gravers.zip
Step 1: Find a screwdriver you are willing to destroy.
These can easily be found for a dime each at yard sales.
Step 2: Use a hacksaw to cut the handle length down to where it can
easily fit inside your hand with thumb extended, just a regular
graver handle. Sand down the resulting rough edges for safer
handling.
Step 3: Using a permanent laundry marker, mark where your thumb ends
as you hold the graver.
Step 4: Hold the handle inside a vise. Use a cutoff wheel to mark the
top side in front of the handle with 3 shallow notches, the bottom
side with 2. This will indicate the top and bottom of the tool
respectively during use.
Step 5: Cut off the screwdriver blade, at about an inch beyond the
laundry mark, using the cutoff wheel.
Step 6: Use the stone side of a bench grinder to deburr the cut and
to make the end parallel with the handle.
Step 7: Cut the heel first, 45 degrees give or take with a slight
bend, based on your experience as a graver.
Having none, I judged this a good start. This has been advised to me
on at least one engraving group. This way, you have the proper angle
already before sharpening.
Step 8: Cut a “foot” just behind the heel. That is, given that we
dealing with a screwdriver shaft rather than commercial graver
material, we need to be sure that the pattern on the heel is
responsible for the line being cut.
Step 9: Cut desired shape on the heel, based on standard patterns for
gravers.
Sharpen the pattern to knife edge, test point with thumbnail so that
the point stays on thumbnail.
Not having a stone handy, I held my graver in a vise and sharpened
the edges with a Dremel chain-saw dressing bit.
That dressing bit keeps them “sharp enough” for a little while.
These are my results on converting screwdrivers into gravers.
These are the tips on the gravers, close up. I made an onglette,
flat, round, lozenge, and knife.
The lozenge was my first attempt. I’m going to try that one again,
later.
I don’t know if these are the largest ones I should make or smaller
to complete the collection. I can always damage more screwdrivers at
10 for a $1.00 USD.
Comments and advice?
Andrew Jonathan Fine
