Greeting all,
Couple of unrelated questions:
What is a good, low maintenance lubricant for trim saws to replace
Petrochemicals like diesel.
With the phasing out of Silicon Carbide (Wet & Dry) paper what are
people using as a replacement?
Regards,
Mark Webb
- What is a good, low maintenance lubricant for trim saws to replace
Petrochemicals like diesel. A vegetable cooking oil like olive oil or a cheaper one perhaps.
- With the phasing out of Silicon Carbide (Wet & Dry) paper what are
people using as a replacement? Mark Webb
Why are they phasing them out? I hadn’t heard about this.
Charles
Brain Press
Box 1624, Ste M, Calgary,
Alberta, T2P 2L7, Canada
Tel: 403-263-3955 Fax: 403-283-9053
Email: @Charles_Lewton-Brain
Metals info download web site:
Learning Center - Ganoksin Jewelry Making Community Product descriptions:
https://www.ganoksin.com/kosana/brain/brain.htm
Greeting all,
Regards,
Mark Webb
Mark: I ran across an article in Rock & Gem here a few months back
saying that anitfreeze is a cheap and perfect solution. Its what I
have in one of my trim saws and I use rubber gloves when cutting. The
antifreeze is water soluble so washes right off. There is also stuff
you can buy called Cool Lube that mixes with water thats maybe less
nasty than antifreeze, you might look for that also. Dave
Art Jewelry for Conscious People
http://www.opendoor.com/stephensdesign/crystalguy.html
CL> 1) What is a good, low maintenance lubricant for trim saws
CL> 2) With the phasing out of Silicon Carbide (Wet & Dry) paper what
are people using as a replacement? Mark Webb
CL> Why are they phasing them out? I hadn’t heard about this. CL>
Charles
Almost any inexpensive easy-flowing low viscosity oil will do -
after all it is only to keep the blade cool. Water tends to
promote rust in the interstices where the tiny diamonds live. If
you want to make the oil flow even more freely, add a little
VEGETABLE turpentine - it’ll make it smell good too! The small
amount you’ll need won’t add too much to the fire hazard, but I’m
sure you take care anyway:-) Don’t you? And wipe the blade when
finished. Don’t you?
We can buy most grades of silcicon carbide wet-and-dry paper in
any DIY tool store. I wouldn’t be surprised if your store
salesperson never heard it called silicon carbide, but did have
some in stock - we suffer from those too!
/ / John Burgess
/ /__ johnb@ts.co.nz
/ (___) \
(_________)
