Anyone interested in the continuing evolution of the pancake (RT Die)
die cutting process might want to mosey on over to the Bonny Doon
forum for a look. I’ve posted a number of pix of recent/past projects
as well at
http://www.bonnydoonengineering.com/ceilidh/ceilidh.html
scroll down a bit to find the most recent pic of mine from July 9.
Though fairly simple in concept, a tabless RT die presents several
major challenges, and these 2 star dies even more so because they
are cutting 3 and 4 parts at a time, respectively. They also had to
be very symmetrical and precise so that any tip of any star would fit
into the nifty hole punch I made for my manual Diacro press. It may
be useful to remember that I am not a machinist and don’t have
anything resembling a modern tool& die making shop. These tools are
mostly handmade, with just the basic drillpress, bandsaw, no lathe
or mill or cnc. So if I can do it… well, no, actually I don’t
suggest trying this at home. The unpleasant aspect of any tabless or
"donut-hole "
die using the RT concept is that the stock or part you’re cutting a
hole into the middle of gets trapped inbetween the 2 main plates of
the die. With a donut die the hinge (secondary) plate must be left
intact, and this makes part extraction a slow and awkward affaier.But
with a tabless die (as seen on these 2 star dies )that secondary
plate can be cut away all except the minimum needed to attach the
cutter to it and for it to continue on down and function as a hinge .
This makes it quite a bit easier to cut the scrap/stock and pull it
back over the cutter instead of… what you have to do with the donut
die.
A little video clip would do wonders here, but lacking that, you’ll
have to use the photos and your imagination. In the end, I was able
to do a few thousand perfect little stars -with no nasty tabs to trim
and sand off, and punch a clean hole in each one with no
centerpunching, drilling, or cleanup - in a boatload less time than
previously possible.
So welcome a little further into my world, somewhere inbetween
low-tech and high-tech, between jewelry making and machine shop, and
as always, here to serve.
Dar Shelton, (“The Sheltech Guy”)
