I have owned a Cavallin mill for many years. It was a good mill.
If you want a Great quality mill than get a durston If you don’t want
to get a great quality mill, get a cheap mill. You get what you pay
for.
I personally own a Durston mill. I have found that the quality is
exceptional and the Durston mill is smoother when rolling, which
tends to give me better quality material when I am done.
Next: Ferrous are metals and alloys containing iron; non-ferrous
materials do not do not Ferrous metals include mild steel, carbon
steel, stainless steel, cast iron, and wrought iron.
http://www.ganoksin.com/gnkurl/ep8249
No, you should Not run Ferrous metals through your mill unless you
ensureyou have protected the rolls on that mill. There are ways of
doing this.
Ferris metals usually contain iron and are not usually safe in your
mill.
One exception would be the Bonny Doon texture plates.
The Bonny doon texture plates are designed to be run through your
mill without damaging your rollers.
Otherwise you should stick to gold, silver, copper, brass or
standard jewelry metals.
I have never had an issue running jewelry metals through my mills,
Durstonor otherwise.
You can damage any too if you abuse. Stop by my workshop. I will
show youa few.
I can break or damage almost anything.
If you use your Durston mill correctly, as intended, it will perform
flawlessly. Abuse it and you will damage it.
Read about your mill and learn to use your mill correctly.
If anyone needs or wants assistance with their mill or help choosing
a mill, any mill,. Please contact our technical support specialists.
We are here to help.
Happy New year
Phillip Scott
Graduate Gemologist
Technical Support Specialist
Rio Grande, A Berkshire Hathaway Company
1.888.225.6656
