Debby and all, In general you will not be able to buy a manual
Rolling Mill which opens up to 10mm. However, we can supply a Rolling
Mill which can be used for rolling between 5 and 10mm. This is a
standard Rolling Mill but with a special set of gears. If you then
wanted to roll down to between 0mm and 5mm you would need to remove
the special gears and replace with standard. The change over time
would be about 2-3 minutes. It is not necessarily the ideal solution
because it will become inconvenient removing gears. The other option
is to have two machines but this is not ideal either. No 1: Taking up
too much space. No 2: Too expensive. Regards, Sara Durston
Durston Rolling Mills
Progress House, Hospital Hill
Waterside, Chesham, Bucks. HP5 1PJ England.
Tel: + 44 1494 793244 Fax: + 44 1494 792966
email:@Durston_Rolling_Mill Web:www.durston.com
