Can anyone recommend some sites or companies please. Are second
hand machines worth looking at. Is a cheap machine worth getting
or do you have to get a top of the line one. I am based in New
Zealand. Thank you very much for your help.
Good questions!
You might consider a laser from Neutec USA. The machine is made in
the USA. Parts on the shelf. Their laser has a longer flash lamp
life than others on the market. The consumables are considerably
less expensive as well. The Neutec machine has 24/7 tech support
and uses the energy of the laser more efficiently than other
machines on the market.
There are many good machines on the market. Used machines would not
be the way to go in my opinion. You do not know the history of the
machine and consumable costs will be dramatically higher than the
newer technology. There could be other problems with the machine,
which is why they are getting rid of it. Flash lamps that needed to
be replaced every year or so are now lasting 4-6 years or longer.
The new machines also are able to handle silver very easily now,
where before you needed very high power settings or a stronger
machine to do the work. The new machines use the energy more
efficiently, using lower power settings to do the same amount of
work. This allows the flash lamp to last longer.
For more info you can contact us at 1-800-545-6566 and ask for
Technical Support, and we can discuss benefits of many of the
Respectfully,
Phillip Scott
Technical Support & Sales
Rio Grande
1-800-545-6566
