Ok. I know this is stupid, dangerous and a freshman mistake. I
recently upgraded to an EZ Torch disposable propane tank set up. I
formerly used a bernzomatic butane mini torch / creme brulee type
torch. I haven’t had any training on this type of torch obviously
with my post title Anyway, I forgot to vent the propane out of
my torch the last time I worked (2 weeks ago). When I turned on the
gas a light ocher colored goo, petroleum jelly-like, started oozing
and spraying from the nozzle/torch tip. I shut off the gas
immediately then took the tank set up outside and fully vented the
hose. As I did the gas venting became “white” and started smelling
horribly. So I opened up the valve on the tank hoping that the
remaining gas in the tank wasn’t fouled. It seemed to clear after a
minute. I called Otto Frei. We figured out the propane coagulated in
the hose from not venting.The tank is stored upright at all times so
it’s not from being on it’s side. It was suggested that I take the
hose and nozzle and tips to a compressed air pump and clean it. I am
wondering if this will remove all of the jelly or will it need to be
“degreased” by soaking the hose in a mild soapy water. I am also
wondering if the interity of the hose is still viable after sitting
for 2 weeks with a fuel jelling on it’s interior. Feel free to call
me an idiot as long as you have some ideas of how to clean my torch
so I can use it again (wiser for the moment). I have some rather
stupid mistakes under my belt, thank God I’m still alive and
“hacking” away
thanks, Liz
mielemelograno.us
