Was: Fusing 22 karat gold
Greetings All,
Thank you to All the Kind Contributors who have helped me on my
journey. After a month of research and inquiry I have learned that
the method used for granulation can also be used for sheet to sheet
connection and wire to sheet connections. This is the path I will
explore. Along the way I came across something I felt others might
enjoy.
Here is an application for a patent, filed in 1908, by Georg
Schneider. The application is for the Process of Producing Verdigris
using malachite and azurite.
http://www.ganoksin.com/gnkurl/ep81kj [PDF file]
If I may be indulged further a new question has developed. Which is
the best copper salt to join 22 karat gold; copper acetate, copper
carbonate or copper oxide? I will use gum tragacanth (that I found
online, thank you), a little Batterns flux and plenty of
experimentation.
I am making copper acetate (verdigris) according to the instruction
in this video but it takes a month and would like to try a faster
method. Any thoughts? How to Make verdigris with copper and vinegar « Science Experiments :: WonderHowTo
Kind regards,
Lois Gore
