Donna,
unless you melt some one’s ring down yourself, the chances are that
no refiner is going to separate out one single item and assay it (a
minimum charge of 75$ at H&S and more at other refiners) melt it down
separate from the rest of your scrap and then return it to you
prefabricated (as a sheet, wire, etc in the dimensions you specify)
on a scrap refining order. sorry to say but I think the mistake was
yours in this particular case. Once you understand how they (H&S)
handle refining ( it’s in their catalog and on their website) without
calling Stewart Grice, the manager of their refining department
yourself and requesting, in advance what you are proposing they do
with a single band ( read: a couple of grams of Au) and asking
whether or not it is a possibility and what extra charges will be
incurred for special handling, the possibility that someone that
routinely handles scrap all day every day is going to deviate from
how they operate is rather slim…regardless of what notes you tape to
which baggie…
Otherwise gold is gold and once it is melted from that original ring
(your customer wanted fabricated into earrings) whatever "energy"
that was attached was consumed in the fire…don’t you think?
I also pose this question: If H&S sent you two pieces of sheet of the
same karat, size and colour, how would you have been able to tell
which was the one containing the ring’s content?..
As you said this was your first and only experience with H&S…but I
for one, have experience with at least 5 currently operating refiners
and Hoover and Strong is hands down the most honest, most reasonable
assayists, and their employees are truly customer service
oriented…the secretary you spoke with is in a different building
entirely from the refining division and told you she communicated
your request to the refinery…
Other than your calling the refining department yourself, or simply
melting down the ring yourself and rolling it out, I am puzzled at
your expectations of the entire system…I encourage my students to
refine and reuse their scrap- in fact that is one of the first topic
areas I cover with them and add a discussion of outsourced refineries
( hoover and strong being my personal recommendation every time for
all metals) and how the process works…I don’t intend to imply that
you did anything wrong in this case,(- in fact it was that you were
aiming to please your customer…)
just that you weren’t aware of how refining works once a parcel of
scrap leaves your studio. But once you realized what happened do you
think it was necessary to tell your customer that it was not the same
gold, or rather that his gold was mixed with the rest of your
scrap…gold is gold…his gold may now be combined with gold from
ancient civilizations, etc. the point is how, unless handling it
entirely oneself,can anyone tell the origin of the gold in your
work…
True, it is unfortunate that his ring was lost in processing, but 10
times out of 10 the gold one receives from the refiner as a
settlement is not the gold sent in…basic and true of most ( united
precious metals in Alden NY where you can go watch “your” gold get
processed if you desire may be the exception).Understanding the
process is the key here. Had you known, or had any previous
experience with refining you probably would not have told your
customer that you could guarantee his gold would be retrieved…
rer
