I started by melting my wife's wedding ring, making it into wire,
and started doing things.
Far out ?!?!?!? If I did that Iād get my nuts served to me on a bed
of rice My wife is definitely not that forgiving
Stay away from casting! Fabricate things by hand.
Why not just do everything, then if a job comes up that demands it
youāll at least know where to start?
Basically I like to know how to do lots of different things, be a
jack-of-all. Iām just starting out with jewellery as a craft, so Iām
trying to give myself the best of all possible chances without
limiting myself.
I like to make rings by hand for practical reasons, but I like to
cast ingots and features, then add them to my work.
In case of individual pieces it is much cheaper to fabricate.
Well not always, as itās been pointed out in other posts, it can
take a lot of time to fabricate individual sculptural pieces that
have been carved in wax first. Time is money, unless youāre making
jewellery thatās not for sale.
A lot of students buying ready made chains, setting, locks, and
etc. Do you know what you pay per gram buying it ?
I donāt intend to buy ready made anything, but I have started to
scavenge old jewellery, stuff that my wife will let me re-model.
Have no idea how much per gram to buy ready made, but would hazard a
guess that it would include a manufacturers overhead.
Do you know how many things can be made from couple of feet of
wire? The biggest difference in working with precious metals as
compared to other metals, is that precious metals are not available
in any size and form. It is probably not true anymore, but when I
started, we treasured every tiniest piece of scrap. Everything was
used for something. Do you know where term "findings" come from?
Look it up.
Probably a lot, but Iām not using a wire precious wire at the
moment, it just hasnāt come up in the class yet. I do have a side
project making replica Anglo-Saxon tin bronze coil rings, and am
drawing an ingot of tin bronze into 2mm wire.
I am curios. Do you have any of my DVDs. If you don't, you should.
Iām saving up to by metal and a precision gas torch (the one that
metls open crucibles). I probably will buy your DVDs, but it will be
in another 2 1/2 years. Currently Iām learning Australian industry
standards and practices, I need to focus on those, so I can pass my
tests.
I do not mean previews. Previews are just that. The useful info in
on DVDs themselves. When you watch it, pay attention how little
metal it take to create a form, if proper technique is used. And
the metal itself is square wire, or flattened square wire, which is
very easy to make, even with the most primitive rolling mill.
I need to get a rolling mill, the cheapest Iāve seen is about $600
AUD. I was tempted to buy these plans
The McDonald Mill : Anvilfire Plans Review and make the
rolling mill, as it would serve a few other functions. A bit worried
about losing fingers though.
A friend made one http://fenrisforge.com, and finds it a treat to
use.
Regards Charles A.
