The grain structure of castings do not have to be large. As-cast
grain size is a function of many variables not the least of which
are composition and metal/mold temperature differences. Spaces
between crystals are no larger because of cooling rate. Grain
boundary “spaces” are of a size approximating that of the largest
crystal in the alloy. You are talking about atomic dimensions here
guys.
If that were only true. The grain structure of as cast silver is
visible to the naked eye if you etch with the proper reagent.
Cooling rate is one of the major influences on the vacancies in the
crystal structure that accumulate to form the dislocations in the
crystal lattice that break up the symmetry of the cast metal
structure. If you were to cool the metal at a very slow rate the
crystals would be more nearly perfect in shape. The discontinuities
in the lattice are what allow the metal to be worked with a hammer,
if it had a more perfect crystal structure the metal would not be
malleable the perfect crystal structure would make it more rigid.
The large crystal structure provides larger discontinuities
between the grain boundary regions which make for easier formation
of fractures along those boundaries. This is why a forged tool is
better than a cast one. The smaller size of the crystals and
discontinuities produced by hammering forms a denser compact
lattice that is less likely to fracture. You are right in that the
crystal structure does not have to be large but to keep the grain
size down you must cool the sterling fast which produces a more
highly stressed casting. In the extreme this will shatter the
metal.
There might be debris/inclusion material at the grain boundary’s
that make them look large but what you are seeing is an area that
was probably the last to solidify.
Sterling silver in the cast condition is hetrogeneous. The outer
parts of the crystals are richer in copper than the inner. At the
crystal boundary is where the copper oxides form as the silver
releases the oxygen it absorbed while molten ( up to 10 times its
volume in oxygen can be absorbed by molten silver ) the copper will
not release the oxygen it absorbs and this is the dreaded “fire
stain” it forms on the outer layer of the crystals. The combination
of this oxide layer and the eutectic alloy which is the last part
to solidify are the things that can delineate the crystal
boundaries to the naked eye.
There was insufficient liquid
metal to fill the voids during solidification. That BTW is part of
the definition of shrinkage. Which is probably the most prevalent
defect to be found under a sprue.
Gas porosity is the more likely culprit in sterling castings.
Examine the voids if they are round then they are gas if they are
elongated and look torn then they are shrinkage.
You can cause this defect by quenching a casting to early.
You can shatter it due to the high thermal shock shrinkage is
generally a slower phenomenon.
However, if you wait 5-10 minutes in most castings you have a
completely solidified casting. The tree may be liquid but most
castings are solid after 5 minutes. > Varying rates of
solidification do cause stresses. A good anneal of as cast
product does prepare it for subsequent hammering without
cracking.
This anneal will only help if the flask was cooled too rapidly
and unevenly after pouring, otherwise it makes no difference to the
malleability of the metal. And the metal will still be more libel
to fracture due to the large discontinuities of as cast metal.
However. this varies with the alloy. Silver alloys are
available that are soft and "stress free" if cast properly.
Yes but they will not be sterling which is only 92.5 % silver and
7.5% copper the addition of other metals as grain refiners and
de-oxidizers create a different type of silver alloy.
Jim
@jbin
James Binnion Metal Arts
2916 Chapman St
Oakland, CA 94601
510-436-3552
