I am looking for advice on purchasing a portable soldering system
for soldering ‘large’ pierced overlay projects. ‘Large’ is really
only a 1’x2’ pierced pattern to be soldered to a 1’x6’ sheet. A
bracelet type project. Is Mapp gas hot enough? Or is propane OK?
What supplier can I order a screw on hose and torch tip. Do you
think a Plumbing store would have the tool I need or perhaps Home
Depot? Thanks for any advice.
You can use the little torch with propane and oxygen in the little
bottles made for a plumbers torch. I’ve been using the little propane
bottle in my home shop. The whole setup would fit in a small tool bag
