I could use a tool that provides a narrow strip (~3mm) of
sandpaper on a firm (and also narrow) "stick" where I can easily
and frequently advance the sandpaper to a fresh surface.
Hi Dale, There is actually such a tool! Try page 392 of Rio Grande’s
2003 Tools & Equipment catalog – check out item “A”: 3M Imperial
Micro-Finishing Sanding Stick Kit.
Hope this helps,
Jessica in SF, where I watched last night’s lunar eclipse from my couch.
The 3M micron-graded Wetordry Tri-M-ite polishing papers give a
mirror finish if you go thru the 6 grits on a flat surface with no
polishing on the buff necessary! Fantastic for getting a true flat
surface especially good for avoiding buff drag on pierced pieces.
This product really changed my life! Try the sample pack from Rio,
P.390.
Need a very small sanding stick which will reach into prong settings?
Take an old hacksaw blade, grind off the teeth and profile like a
barrette file. Round the edges and back by sanding and polish the
edges smooth. Now with double face tape, stick " Imperial Microfinish
film " on the saw blade. Trim off the excess with a sharp knife.
Available from RioGrande . Get the assortment pack. RioGrande is
still in my book. A great " find it " place.
Hi there, the sanding sticks i use are about 4cm wide and 6mm thick.
The length is slightly longer than the emery paper. One thing I find
helpful is to score the emery paper (paper side) so that it makes a
nice crisp line when folded. I also use a rubber ‘o’ ring to hold
the emery paper on the stick. Eileen
they are flexible, contour to your piece and do a fabulous job.
Sorry to contradict, but if you want to keep a flat surface flat,
your sanding tool needs to be rigid, not flexible. The act of
contouring to the piece will cause flat surfaces to become rounded
off.
