Okay, I’ve found some useful(?) links on how hard 1000 parts platinum
can get and here it is - 300 HV (!). To achieve this it seems the
1000 plat. is mixed with tiny amount of gold.
As I understand it, Pilot offers two 1000 plat.solutions: Ptau and
UHP1000.
And the weirder thing is that a 4 mm Ptau plat. ring weighs around
5.5 gram, , while a Plat/palladium ring sold in Sweden, with
same width and abt 2 mm thick weighs over 10 grams!
The sites I’ve found are in Japanese, but babelfish.altavista.com
does help little.
Here it goes (long story):
*As for the deformation test item it is in a state where it is
tested by the 30kg load. Deformation strength differs
(depending upon design)
*The frictional scratch test the marketing wire brush (is
scratch state of the surface after the true) with 50 time
brushings make.
Both the deformation test frictional scratch test, the simple
shell circle (width 3mm, Koudaka 1.5mm, size 12) it tested with
form.
The ultra hard platinum UHP1000 which exceeds the hard
platinum.
In daily life it is the suitable material in the marriage ring
which has the durability which is strong in strength and the
scratch which it does not become deformed.
We draw the line where the inside of the ring is smooth, fit
to the finger easily.
It is finished in the smooth film which freely uses the
precious metal process technology which is cultivated with the
fountain pen, does not have connection.
The invention of UHP1000 is recognized as platinum guild
international (PGI) from Pt1000 Advanced Technology
Development support prize the prize winning (1997) it is the
only new technology which is done. UHP... diamond pyramid
hardness 200Hv PT1000 hard bullion... diamond pyramid hardness
90 - 120Hv (Diamond pyramid hardness the extent whose numerical
value is high means hard thing)
Is the new material just of the pilot which is strong in
deformation and the scratch(patent acquisition end)
FFF (finger fine fitting) per finger is satisfactory in the
design. High accuracy finish only of pilot
As for Pt G1000, the pure platinum which PILOT actualizes for
the first time (diamond pyramid hardness: Hv50) with pure gold
(same: With the alloy of the precious metal 100% which Hv40) 1
to it hybridized at ratio of 1, does not have example in other
things, you are proud of the super hardness, Hv300, (* during
patent applying). In daily life the durability which is
superior rub vis-a-vis the scar and deformation is shown.
Because it consists of the pure platinum and the pure gold, it
is 100% high purity as a precious metal.
Ptau (Pitot) super hardness & precious metal 100% Pt
(platinum) Au (gold) =Ptau (Pitot)
With the completely new marriage ring where Ptau (Pitot), Pt
G1000 was built up in the material, as the anniversary ring
which celebrates time-honored marriage we recommend. Pt G1000,
with the alloy of the precious metal 100% which does not have
example, to other than the pure platinum and the pure gold
which PILOT actualizes for the first time, Hv300 * with is
proud of the super hardness which is said. In addition, in
order to be easy to set also all product, easily to fit, the
endophragmal skeleton circular finish is administered. * As for
the pure platinum hardness Hv50, as for the pure gold it is
Hv40, but Ptau which is the alloy of the platinum and the gold
achieves the hardness, Hv300, shows preeminent durability
vis-a-vis the scar and deformation."
Pheew. I have exhausted Babelfish.
B rgds
Keo
