Hello Grace, The recipe for Prip’s Flux has been on Orchid many
times, but I’ll copy Peter Rowe’s words heRe:
“The recipe I’ve always used is ONE quart of ordinary tap water, 80
grams each of borax and TSP, and 120 grams of Boric acid. It’s the
2:2:3 ratio of the chemicals that matters, not the quantity of water.
In one quart of water, boiling, the above chemicals will not quite
dissolve completely, so you then add sufficient additional water to
finish dissolving them. The idea is to make up the most saturated
solution you can, so you don’t have to spray so much to get
sufficient coverage. But there’s nothing wrong, really, with making
it up much more dilute, if you wish.”
TSP stands for TriSodium Phosphate, and be sure that you get the real
stuff. In the effort to reduce phosphates in the environment, TSP
has been eliminated from many store’s stock. I get mine at a paint
store. Borax comes from the laundry section at the grocery store and
Boric acid from the pharmacy. After you have the flux all mixed and
cooled, pour it into a plastic bottle and cap well. For application
I reuse one of those misting pump spray bottles from body spray. To
keep the silly nozzle from clogging from day to day, simply fill the
little cap (that covers the pump) with water, invert the mister, and
put it into the water-filled cap until it snaps on. Store it upside-
down in a heavy container. When you next go to your bench, remove
the cap - keeping it upside down unless you want water to run down
your hand. Voila’ no clogging. You will find that the saturated
solution you have made will precipitate out with time. Not to worry
- just reheat with some additional water.
So far as the ProCraft Pickle, I don’t know of it. I use citric acid
solution and there have been many discussions about using sodium
bisulphATE - as John Burgess posted recently, “it is an excellent
jewellery pickle. It is also sold by pool and spa shops as a pH
modifier, and is far cheaper than Sparex, despite being identical.”
When the pickle is spent, I use common baking soda to neutralize it
before disposing down the drain. Hope this helps. Judy in Kansas
Judy M. Willingham, R.S.
Extension Associate
221 Call Hall Kansas State Univerisity
Manhattan KS 66506
(785) 532-1213 FAX (785) 532-5681
