Judy Bjorkman,
As far as I could tell from Amy’s post her student’s copper plating
was the result of pickling the brass and not heating the brass.
A cuprous oxide or a red heat patina that can be achieve on copper is
more difficult to achieve on brass. The color of the copper left by a
zinc depletion plating is a dull soft copper and not as intense as
the red heat patina of cuprous oxide.
Since we can not see the metal we are discussing, I based my
assessment on the years of similar experiences I had while teaching
metalsmithing at the college level. I also experienced the zinc
depletion plating of brass as journeyman goldsmith while finishing a
brass sample line.
Back in the late 1970s road reps would carry small independent
jewelry maker’s lines around the country taking orders. Often the
jewelry makers could not afford to send out “live” goods (real gold &
diamonds) lest they be stolen.
So brass samples with cz’s where made and gold plated. Often the
brass samples did not cast as well as would be hoped for and repair
work would need to be done, thus the soldering, the pickling, the
zinc depletion and copper plating.
If you find this difficult to believe, test it for yourself. place a
piece of cold brass in cold pickle and within an hour you will begin
to see a dull copper (zinc depletion) plating occur on the brass. Of
course heat speeds this process. And while some zinc may oxidize
during soldering procedures, even without any heat, pickle will
dissolve zinc from the surface of brass.
Nanz Aalund
Associate Editor / Art Jewelry magazine
21027 Crossroads Circle / Waukesha WI 53187-1612
262.796.8776 ext.228
