I have a necklace of keshi pearls on a silver chain. The links for each pearl appear to be soldered. How could I do this?
The only thing I’ve come up with is that two posts with rings already soldered are glued into each pearl? Or is there a super efficient way of protecting a pearl while it is soldered?
Hi,
could you post a pic of what it looks like?
julie
Without a picture I’m not sure what you are looking for. But here is a video that shows how to make a necklace of pearls on a fine chain. No soldering is required. I have make a chain like this and it looks great.
Hi Vera,
great link! thank you for sharing! geniys!
julie
Thank you. One of the best things about making jewelry is that even after 5 decades I still learn something new every day.
Jo
Where would one find drill bits like that? Thanks.
Looks like a small pearl or bead reamer mounted in a # 30 flexshaft handpiece.
Fabulous, found it, just needed the name. Thank you.
Or could it be a fine cutting broach?
A watch maker gave me a couple years ago.
Cheers willie
I have made these a couple of times with freshwater pearls…that is, inexpensive pearls. At first I used a fine watchmakers broach to open the holes. It was a bit time consuming. Then I tried using a .6 mm drill bit, rotating slowly and moving in and out. With bit small enough to go in the hole the in/out movement and slow hand piece speed it is easy to ream out the hole. I would not suggest using a larger bit and drilling like you would with metal. BTW, I managed to not ruin a pearl with this technique, but I would be a little nervous with expensive pearls. Oh, and the other thing I did was take a small ball bur and rotate by hand to smooth the edges of the holes.
Hi Vera!
…I dip in water to contain the organic dust debris…
julie
Here in the UK the BBC ran a jewellery competion this Autumn called “All that Glitters”. If you can get access to it on youtube there was a pearl challenge I think it was in episode 3 and one of the contestants made a soldered pearl chain.
Good luck.
Jo—for every 100 things you teach us we give you one back!
Otto Frei has drill bits as small as .5mm here: https://www.ottofrei.com/Busch-Fig-77-Tungsten-Vanadium-Twist-Drills-on-3-32-Shanks-.50mm-2.30mm
And I used 30 gauge wire (Rio Grande)
