Patina - provoking rust on iron?
Does anyone have a formula for provoking rust on iron?
I’ve been informed that salt, vinegar and hydrogen peroxide will
work.
Does anyone know the proportions?
Take a paper towel, and soak it with bleach, then put the paper
towel on it and it will rust very quickly, like within minutes.
Chris
Tony, I found this page for rust patina on iron or steel on
instructables… http://www.ganoksin.com/gnkurl/ep7zdw
Barbara on a rare muggy night on the Island.
Hi All;
There is a very effective product out there called “Plum Brown
Barrel Finish” which can be found in gun shops and I’ve also seen it
in Wal Mart’s gun section. I can recommend it for its results, but it
needs to be handled very carefully as it is quite toxic. An
alternative would be ferric chloride. A liquid form of this can be
bought at Radio Shack or other electronics stores and is used for
etching circuit boards. Of course, chemical supply houses will have
it in dry form. It is not something you’d want to drink, but it is
fairly safe aside from its being an oxidizing agent. If you expose
fabric, wood or paper to it, you have to rinse it out thoroughly
before discarding it as it will become quite flammable when it dries.
You can apply it to a warmed article for faster effect, but repeated
applications on a cold iron or steel item willl result in rusting.
David L. Huffman
