Materials: bronze, nickel, brass
Dimensions: 5.625"h x 6.5"w x 6"d
The 2012 Super Bowl Challenge piece. The bowl was first sunk with two sections then pierced out. Nickel was chased with tiny bumps, shaped to fit the bowl, and then riveted in place. A matching base was made out if nickel.
Wendy Edsall-Kerwin
Elizabethtown, PA. USA
Metal. To many it is hard, rigid, and immovable. But metal flows, bends, and can be worked over and over again. It is both industrial and organic. Through processes such as fold forming, forging, and riveting, I am able to work with this dual nature, to connect with my materials.
These techniques have also allowed me to explore texture and pattern in new ways. To bring more depth to my work, I use layers, folds, and textures on the metal. Using rivets rather than soldering pieces together puts focus on the different parts that make up each piece. They give a physical presence to the joining, a reminder that someone chose these parts to make a whole.
