Have been looking and reading for some time and now have a question
perhaps one of you may answer. What qualifies as “new” metal in
casting? Have been using offcut Sterling Sheet in 50/50 combo with
old buttons, sprues, etc. Am getting porosity particularly at point
of entry [more pronounced] as well as further into the piece [very
fine]. Is this an alloy problem [offcut sheet not “new”?], sprueing
problem [turbulence?], flask temp. problem or am I just not holding
my tongue properly.
my tongue properly.
For the best results, use new casting grain from a metal supplier:
this contains silicon which acts as a ‘sponge’ and removes oxygen
from the metal very efficiently. This can very successfully be
mixed 50/50 with old sprues and buttons. The offcuts of new sheet
do not have this property and while they will probably be OK on
their own, mixed 50/50, the chances of porosity are increased. The
only other thing that I would suggest is that you make sure that
your temperatures are as low as it is possible to cast at and this
should prevent porosity even using plain old sprues and buttons,
however, if you do this, you may have to ensure that the sprues on
your patterns are quite large.
It may be all three. The porosity at the sprue is due to too
small a sprue or a melt brought up to melting point butnot
casting temp. Are your buttons remelted on a charcoal block and
fluxed? I think I can assure you that for the most part how you
hold your tongue is only significant when dealing with your wife!
Mine is always telling me to hold my tongue. If you are
experiencing porosity, be sure that everything is clean of
investment and any kind of dreck or dirt. Be sure that you get
the metal to casting temp, and be sure to use a quality casting
flux. The micro-porosity problem sounds like it is a sprueing
problem. Good luck and if you need to E-mail me off line if you
wish.
Regards,
Skip
Skip Meister
NRA Endowment and
Instructor
@Skip_Meister
03/16/9819:09:50
