Didn't anyone ever see the little brass knob on the bottom of the saw frame? If you put the saw blade in both the top and bottom slots and tighten them.......set the little brass knob on the table top and pull down on the handle, then tighten the screw at the bend of the metal frame - you will get a nice ping and never have to put the handle in your chest again.
That, of course, works, and you have to do it should you wish to use
a blade that’s longer or shorter than standard.
But frankly, I find that a lot slower to do. More operations than
tensioning at the same time as clamping the blades.
Also, you’re changing the length of the frame. If you then break a
blade, in order to install the new one, if you don’t wish to compress
the frame in the usual “frame to chest press” method, then you have
to first loosen that nut, shorten the frame, then install the blade
and lengthen to tension again. While that certainly works, it’s
slower both in number of operations and also that one might be
holding the frame it a seperate postion to tension this way, than
one holds it to install the blade. I find that cumbersome. But I also
don’t mind pressing the frame in with my chest.
Back to the Knew Concept saw, though, I would mention first that I’m
used to the screw system for blade tensioning (you get used to it, so
that installing a blade simply means rolling a finger down the nut in
one direction, clamping the blade, the rolling that nut down the
finger in the other direction to retension the blade. Quick and
simple) However, as often as not, I find it’s even quicker to tension
at least the finer blade sizes (which don’t need much tension) the
old way. While the Knew Concept saws are very rigid, there’s no such
thing as totally rigid, I think, at least not in this context. You
can’t spring the frame in much, but you can spring it in a little,
and often, that’s all I need. Even quicker than using the nut to
tension the blade. You just have to be sure that when installing the
loose end of the blade, it inserts fully into the hole.
This way, you get the benefits of the much more rigid and
lightweight Knew Concept saw, but you get all the speed of the old
ingrained habit of compressing the blade with your chest. So long as
you don’t mind doing that in the first place, it works. The rigidity
of the frame means that the tension you get this way is the same each
time, so even testing for the ping sound isn’t really needed. Doesn’t
work so well with larger blade sizes which need more tension, or for
situations where you may wish more than normal tension on the blade,
but I find it works well with both my aluminum frames and the
titanium one. Also, Lee’s larger handles are rounder and wider at the
bottom too, so there’s less likelyhood of pressing the handle to
one’s chest being uncomfortable…
cheers
Peter Rowe
