Hi all,
I need to construct a torque (aka torc) bangle using 2.5mm Sterling wire and 5mm (or perhaps 6mm) Sterling Silver balls.
Would it be best to create a circular shaft in the silver ball, using a 2.5mm round burr and then solder the wire in, or use the 2.5mm burr to create a “cup” in the wire and solder the ball onto this cup?
Or is there another method that I have totally overlooked?
thanks in advance for your help
Ed
