I have been presented with a stainless steel, 9 multi plate links
which I have been asked to remove a link from. The link pins have a
screwdriver slot on each end but when they are turned, they move
independently but do not unscrew - they just go round and round. Has
anyone come accross this format before and if so, how does it come
to pieces?
Has anyone come accross this format before and if so, how does it come to pieces?
It’s a pin. Knock it out from the non-split end.
Hello Zed, What appears to be a screwdriver slot isn’t. Push the pin
out from the side opposite the “slot” and all will become clear.
Have fun. Tom Arnold
Its a cotter pin probably. Find the ‘round’ end- opposite of the
’slotted’ end, using a small steel pusher like a worn out micro screw
driver, push it out towards the slotted end. You may need to tap
lightly with a very small hammer, but not likely. Most come out with
solid hand pressure.
Ed
