Hi Gang,
Xuron makes a double flush cutter that has a retainer on each side
to keep the wire from flying off after being cut. When I had the
need to cut a number of equal lengths of wire I modified the cutter
a bit.
The 2 sides of the cutter are held together by a shoulder screw &
nut. I removed the screw & one of the ‘retainers’. In place of the
retainer & substituted a bracket that I fashioned from metal with a
thickness equal to the retainer. To the bracket I attached an
adjustable stop. Now I can cut multiple lengths of wire from about
4 mm to 360 mm long.
By adjusting the length & selecting the proper gauge of wire, exact
size granules can be produce with ease.
Dave
