Metal Sealer & Tarnish Inhibitor
I am casting some small pieces (2" x 4") in white bronze for
exterior use. Their background is filled with an epoxy resin. They
will be exposed to harsh northern winters, as well as hot summers.
They will be highly polished, both the metal and the resin, and need
to keep this look.
The solutions I’ve come up with will not work:
Laquer- will not withstand the elements Clear powder coat- the resin
fill will not take the 400 degree temperature of the powder coat
process.
Chrome or other plating- the piece is curved and the resin fill is
ground down to the curvature of the metal piece and polished, any
plating would be removed in the process.
Does anyone have any ideas of what to use?
Thanks-
Andrea
Andrea,
Plating can be done AFTER you do the resin fill.
Dean D. Amick Jr.
Master Goldsmith
Hamilton Jewelers
Andrea,
For the coating, have you investigated a two part colored epoxy resin
such as Ceramit. They have a clear version that is cured by time and
not heat. It is important with this type of resin to make sure you
are mixing in the exact proportions that are recommended by the
manufacturer, otherwise the product will not set up properly.
I think this is a place to start the investigation. Maybe someone
who has lots of experience can add their comments on using this type
of product for your application.
Beth Katz
http://www.myuniquesolutions.com
Paste Solder and Powder Solder for Metalsmiths and Jewelers
Perhaps this place will have a product that will help you:
http://www.ganoksin.com/resources/detail-sculpt_nouveau-2102.html
Sculpt Nouveau
https://www.ganoksin.com/resources/detail-sculpt_nouveau-2102.html
  a manufacturer of patina and finishing products for all metals,
  also stock metal coatings to be used with our Patinas.
Help others make informed buying decisions with Sculpt Nouveau. We
welcome your opinions and experiences with their products, ordering,
customer service and and over all satisfaction.
Write an Anonymous Review
http://www.ganoksin.com/resources/review.php?id=2102
