Re - Victor Journeyman Torches are top of the line torches which
will work well with Acetylene through natural gas. They are system
torches much like the Meco Midget. I have used Victor Torches all 30
- years of my professional career as a Journey man Millwright. You
can not find better. There are other American made torches available
which are well considered, but I have used them seldom if any. DO NOT
consider Asian clone export torches The quality, durability and
safety are not there.
If you are going to be cutting steel get the additional cutting
torch head attachment. If you already have one keep it for cutting
steel. It attaches to the mixing body of the victor combination
torches as an attachment. I have several of the larger victor
torches. I have one slightly smaller but similar called the Victor
Super Range. The mixing bodies will accept any combination of oxygen
and fuel gas. I consider the use of cutting torches as melting
torches to be less efficient and more costly.
If not abused, these mixing bodies ( The lower ends nearest the
hoses ) can be picked up used as a good deal. Take them to a good
welding supply store and have them checked. The newer mixing bodies
have built in flashback arrestors. Good thing to look for.
NEXT order a rosebud made for the fuel gas you will be using if
other than acetylene. Specify this to the dealer. Rosebuds for other
fuel gasses are similar, but not the same. You need the specific fuel
gas rosebud to stabilize the torch flame. Smaller brazing & gas
welding tips can be used, but need modifying to work well.
If You already have a cutting torch, DO NOT TIE DOWN THE HANDLE of
the cutting attachment ( If the entire torch is all one piece, it can
be used but will always be a poor compromise for melting & casting. )
Do the following.
For the cutting torch - Snug closed all valves and use moderate
pressure to hand fasten the cutting head. The cutting head has a
valve, close it… It is just for allowing the oxygen cutting jet
through the cutting tip. Ignore the handle it will not function with
the oxygen valve closed. The cutting tip is retained by a special tip
nut. Use light to moderate force when tightening it. The Tips are
numbered from # 000 ( the smallest ) to # 6 or so. Tips are expensive
so take care of them. I would start with a # 4 tip. Open and adjust
the Oxygen and Fuel gas as you normally would.
Use the smallest wrench which will fit. Crescent wrenches can be
used, but again use the shortest and adjust the jaws to fit
properly. Using a short wrench will reduce the likelihood of over
tightening things. A good 10" crescent wrench will work for
everything. DO NOT USE CHANNEL LOCKS OR PIPE WRENCHES. DO NOT
LUBRICATE. USE NO OIL.
If you are considering doing metal working involving steel, than You
will find a good combination torch system like the Victor Journeyman
to be a lifetime investment Other reputable American made torches
should give good service as well. They are not as popular for some
reasons
Not trying to be dogmatic, Just please be careful.
Thanksgiving is an attitude, not just a day. Robb.
