If we take a prong and solder it in the middle. When load is
applied, it is resisted by the whole length of the prong. Soldered
joint conduct loads without any problems. I should add "correctly
soldered joint". If we replace soldered joint with welded one,
most of the load will be concentrated on the joint. Due to the
difference in structure modulus of elasticity is very much
different.
In industrial applications, engineers aware of that fact and make
sure not to exceed structural loads in these areas. In
goldsmithing it is quite another matter. Welding simply replaced
soldered joint without any compensation for deficiency in
conduction of the loads. What used to be soldered, now it is welded
and that results in jewellery of inferior quality. And that is my
point.
As to the question regarding the strength properties of a laser weld
verses a soldered joint, I believe the answer is that the strength
depends more on the details of the craftsmanship than which method
is used for joining. Both methods can lead to weak joints, but both
methods can also result in joints that have full strength.
As a structural engineer and a jeweler, I am qualified to comment on
matters of strength. If the weld is of the same material, then the
modulus of elasticity will be the same. In most cases, the solder
material will be a different alloy from the base material, so one
would expect the modulus to vary the most for a soldered joint. That
said, the modulus of elasticity will be almost the same (within one
or two percent). As with steels, the modulus of elasticity is not
typically the controlling factor when it comes to strength. The yield
strength and the total elongation to failure typically are far more
important for design and machining. Both the yield strength and total
elongation may be very different for the welded joint versus the
soldered joint.
Poor craftsmanship can cause laser welds or solder joints to be
weak. For example, improper cleaning of a surface to be laser welded
may result in cracking that can typically be seen just after the weld
solidifies. Solder joints can also be weak. For example, it is well
known that solder joints can crack if exposed to certain chemicals
used in swimming pools and hot tubes.
Incorrect welding techniques can lead to weak welds. For example,
you cannot expect a strong joint on a thick ring if the materials are
simply butted together and a surface weld is applied. As with
industrial welding, a V-notch will need to be used with the weld
built up from the center. Likewise, if the laser power is set too
high, boiling of the metal may result in small bubbles of gas trapped
in the melt pool. These small bubbles can act just like porosity in a
casting and weaken the solder joint.
Welded joints can be quite strong, having material properties that
sometimes exceed the base material. New laser manufacturing
techniques that laser sinter powdered metals have been found to have
a fine grain structure and are almost completely free of defects
typically seen in castings. I have used my laser welder to repair
castings where the welded material was later hammered and pushed onto
stones. If done correctly, you should not be able to tell that a part
has a laser welded or where a solder joint is (structurally or
aesthetically). In the end, it is the craftsman that will control the
quality that leads to the strength of the weld or the solder joint.
Leonid’s statement “What used to be soldered, now it is welded and
that results in jewellery of inferior quality.”, if true, may be due
more to poor craftsmanship than to an inherent weakness in laser
welds. I am interested in learning more about laser joining failures.
Are there herds of customers bringing their laser welded jewelry in
for repair due to laser joint failures? Maybe we can use such
examples to understand how to improve laser weld craftsmanship.
Respectfully,
Stephen Attaway
www.attawaygems.com
