…a malachite stone. The stone is very dull, is there a way to
polish it?
Try very fine wet and dry sandoaper about 1200 grit to remove any
fine scratches. Then polish with tin oxide mixed to a paste with
water. You can apply this to a clean mop and to the stone. this
should bring it up a treat. Take it quietly (malachite is soft)
and do not let the stone get to hot. Best wishes Gerald.
opalsopalsopals*
Arrowtown Opals & Jewellery *
po. box 17 Arrowtown S.I *
New Zealand *
Ph 64 3 4421288 Fax 64 3 4421488 *
- http://www.netprophet.co.nz/nzsi/opals.htm *
