MACS and Hinges
Dave,
I’m sure you are aware of the way the basic virus works . . Mac are not
exempt…
Jim
Macs aren’t exempt but there are very few Mac viruses compared to the
hundreds in the PC world. I guess working on an IBM machine makes people go
insane so they write virus programs to destroy the PC world.
Enough of that. Anyone have some tips on putting a nice maybe ball end on
hinge pins? I’m doing my first hinge on a small pendant and wonder if
there’s a nicer way to finish off the pin…Dave
Art Jewelry for Conscious People
http://www.opendoor.com/stephensdesign/crystalguy.html
Ded you finish the pin before you assembled the pieeece Anyone have some
Did you assemble the piece before or after finishing?
Dave - I use a longer wire than necessary for the hinge and “ball” the
ends back with my mini torch, then polish up. If you have a tap and die
set, there are also interesting ends you can put on. Also, bezel set a
couple of stones that take heat and solder the (tiny) bezels to the end
of your wire - looks great. Good luck, Mike
PS, someone mentioned stones that are solderable? Would that be jade
(nephrite?) and what others are safe? Dave
Thanks for the hinges info, all the stones are already mounted so I guess
I’m stuck with just riveting it down. NEXT TIME THOUGH…Dave
Diamond is one and there is a list of the heat tolerance of various
stones in GIA but don’t have a copy of it handy perhaps
someone else has it. You might check other texts for such a list
also…Gavin…
Not to the best of my knowledge. The only stones which I believe to
take heat are diamond, ruby, and sapphire. I have however, found that
some lab created emeralds will take heat. THIS IS A GREAT IDEA FOR A
THREAD! WHO ELSE HEATS ON WHAT STONE?
