Where can you get a plastic or wooden draw plate.? I called my regular supplier he said he doesn't have it.
Not to sound too exasperated or short tempered or anything, but
for heavens sake.
Make one. Takes about fifteen minues, max, once you’ve got the
needed tools and material. Neither is complex. It never ceases
to amaze me how many times we, who feel competent to make
jewelry, forget that we can also just as easily make some of the
tools… And this one is really simple to make.
material: Almost any suitably sized piece of lexan, delrin,
etc, or maple, corian, or whatever you like. Should be about
3/8th to half an inch thick, and suitably wide and long for the
series of holes you need. This doesn’t need to be rocket
science. Almost any scrap of fairly hard plastic or hardwood
can do the trick nicely.
Tools: A decent set of ordinary drill bits in the sizes needed.
A plain set in 1/16 inch increments, as most of us have in the
basement already, will work fine. if you’ve got a set of
numbered drills, which are spaced closer together, it’s all the
better. And you’ll need some means of drilling holes with those
drills. A drill press is best, but a portable drill, either
manual or electric, works fine too.
Drill one hole, with each drill bit, running the whole sequence
of your drill set. Then use a countersink, or a file, or
whatever is handy, to smooth/round over both front and back sides
of each hole, so it’s not a sharp edge, but a soft rounded one.
You don’t need a large chamfer on each hole, but you need some.
That’s about all there is too it. If you’ve made it in wood,
some hard wax will make it work better. Delrin or corian etc,
doesn’t need the wax.
And if you really insist on bying a chain plate, I think rio
probably sells one… Or better yet, email me. Tell me how much
you’re willing to pay. If I like the price, I’ll make you one…
Who knows. whole new lucrative career in the custom made tool
biz.
Peter Rowe
