actually, i wouldn’t soak them in novalsan, or a dilution thereof,
as it would turn the metals colours from grey and black( silver) to
bluish and browns (gold) with only a very brief immersion
period…like minutes at most… But for dwellings, structures,
equipment, surfaces, public transportation vehicles, etc it is as
effective of a sanitizer as one can get.
It surpasses bleach ( which actually tends to just coat over
problems in wood for instance, changing the colour and lignin
structure by removing stains or "bleaching " as in exposure to sun
and that reaction ), but also just alkalizes the surfaces…After
hurricane Katrina the american red cross -eventually - began passing
out bleach by the truckloads…and found it, after the fact, did not
effectively kill many of the problems associated with the
floodwaters…formic acid , and formalins being one compound
unaffected and leached out from above ground graveyards that did
unbelievable things to all types of goods from stainless steel bowls
eaten through with holes, to clothing looking as though they were
doused with battery acid to molds and slimes that were back within a
week after treatment. Novalsan was the “secret” ingredient many home
cleaning services began using, along with UV light, and silver
nitrate to kill all sorts of things dead in their tracks…as well as
removing the tracks!.. If i had to be outdoors and wanted to let
people try on earrings ( which would never happen in my case
anyway!) i would get a battery operated small crock pot with a lid
without holes (as some potpourri pots are riddled with), and that
reached at least 120 degrees F if not 209F optimally, or a battery
operated ultrasonic unit and put a solution of peroxide and water in
it and immerse the earring wires for about 5-10 seconds in the
ultrasonic, or up to 9 minutes in the 120 dgree pot or 3 mins in the
209 gegree pot to at least make an effort at removing any problems
that may have stuck to the surface of the metal…bacteria is unlikely
to penetrate the metal particularly silver and gold- which were used
in the past as anti-bacterials and anti-microbials before other
compounds became available…
someone mentioned heat and pressure…
In an outdoor venue- as that is the subject here originally: a 6. 00
solar shower heats water to 226 degrees in under an hour in full
noonday sun- it will scald you… it has a simple hose delivery with
a cut off clamp on one end, and hangs easily-but is heavy when
full… it is an excellent hot rinse to remove whatever has clung to
the earwire -just hold with tweezers!..alternatively take the
superheated water and put it in a sterile container, with a few drops
of hydrogen peroxide or: 1.4 tsp to 1/4 c. water and place in a car
in the sun with rolled up windows and let stand for twenty
minutes…that gives you the heat and pressure you need to rough it
and clean it…sounds bizarre but it is effective… cars are very
overlooked for dehydrating, cooking, canning, and a variety of other
uses-drying PMC/Art Clay rapidly… living without electricity has
taught me many things… and reminded me of more and caused me to
research antiquated methods that are effective for a vast amount of
practical life affairs…
And if one keeps horses, livestock, etc. absolutely no better
substance can be had than Novalsan. Apres katrina we treated our
gutted homes and studios with it, from floor to ceiling and not one
single mold, mildew, slime, bacteria, or virulent anything returned
compared to neighbors still battling the problems because they wont
spend the 22. 00 for a bottle of concentrate that has now become a
standard that home cleaning services have adopted as their “secret
ingredient” in the war against katrina patina… my household gets
pissed that I spend time playing the 'aisle game" in stores, but
knowing what’s in what’s on the shelves and where the shelves are in
what small town near our current residence in exile…It makes me not
only a better consumer but aware of what potential compounds are out
there to begin with and where I can get them and for how much…
should i need a battery operated ultrasonic cleaner, novalsan, or
water glass…
humbly, R. E. R.
