The choice of materials for making a master model really depends on
the intended design and what you are comfortable with. If you’re
good at fabricating objects in metal and this is a simple fabricated
design, then copper might be the way to go. If it requires elaborate
sculpted detail that would be difficult to achieve in metal
directly, then wax or clay might work better - the choice of which
to use depends on what is easiest for you to work with. You could
also combine these media, using clay or wax applied over the copper
in certain areas. If you do decide to use clay, there are a range of
oil-based (Plasticine) clays available, which have some advantages
over water-based (potter’s) clay for this sort of project.
Oil clay doesn’t shrink or crack as it dries, and so it doesn’t mind
hav= ing rigid objects embedded in it. It comes in a range of
hardnesses and formulations, and can be softened with a little heat,
from a hair-dryer, for instance. Check with your mold-maker before
buying the clay - some of them, particularly the ones containing
sulphur, are antagonistic to certain mold rubbers. If you’re the one
who will be making the mold, test for compatibility with the rubber
you plan to use before investing a lot of time in making the model.
Do you make a really big mold for something like this or does it have
to be in two parts and then assembled?
Eight inches wouldn’t qualify as a sculptor’s idea of “really big”,
but I suppose it’s large for a jeweler. Most art bronze casting is
done by making rubber molds of a master model. Into this, wax is
poured, then poured out, leaving a relatively thin layer of wax on
the inside of the mold. This is removed, cleaned up, fitted with
gates and sprues for the metal to flow into and air to flow out,
encased in plaster-silica investmentor ceramic shell, then fired to
remove the wax entirely. Into the resulting void, metal is poured,
usually relying on gravity to fill it. (The centrifugal or vacuum
apparatus used by jewelers to cast metal isn’t necessary once there’s
enough metal melted to overcome surface tension.) You can make rubber
molds in one piece, cutting the rubber to remove the master, or you
can make rubber molds in two or more parts. The rubber inner mold is
usually supported by an outer “mother” mold in plaster or another
rigid material. Depending on the shape, this outer mold will have
one, two,or more parts that are assembled and held together with
rubber bands, clamps, or other fasteners. If you use plaster for the
outer mold, soak it in water before pouring the wax; this prevents
the wax from sticking to the plaster.
Andrew Werby
www.unitedartworks.com
