Hello everyone,
I have made a brass, copper and sterling bracelet for a donation to
be auctioned off for charity.
What, if anything, can I lacquer it with so it all does not discolor
on the winning bidder…I would like it and it’s finishes to last
for as long as possible without turning an awful color.
Any suggestions would be much appreciated.
Thank you in advance,
you all are the best
Laurie
I have made a brass, copper and sterling bracelet.. What, if
anything, can I lacquer it with so it all does not discolor on the
winning bidder...I would like it and its finishes to last for as
Laurie, I work with brass and copper and would not lacquer anything
but a wall-hanging. I suggest that you oxidize (patinate) the
bracelet instead (the base metal will turn black; rub off the excess
with a thick mix of water and pumice). This will give any recesses in
the design nice black shadows, and a slight amount of darkness left
on the inside of the bracelet will prevent/retard the skin on the
wearer’s arm turning green. The only care it will need after that is
an occasional rub with a silver-polishing cloth (a note to that
effect could be included with the bracelet), which it would need even
if the bracelet were all silver.
Lacquer on objects like jewelry eventually wears off and leaves
patchy places. To restore the original finish would mean getting off
the rest of the old lacquer and re-lacquering – tedious processes!
All the best,
Judy Bjorkman
If I must protect metal w/ a lacquer I use Nikolas #2105 Clear
Lacquer spray. When dry (15 minutes between 2-3 coats, esp in summer
weather) the surface is a water clear gloss. Only trouble, you need
to buy by the case of 12 cans, I believe. To remove, soak in lacquer
thinner. It’s a terrific product. When we need to, jewelry friends
split a case.
http://www.finish1.com
Kay Taylor
