Sounds as if you do a lot of kum-boo foil making. Would you
please share your techniques for rolling the metal to the
proper gauge? Do you use an electric mill? Do you roll the gold
between sheets of something else? Etc..? Having a variety of
colors to work with sounds interesting. Is there a Webb site to
view your work?
My apologies to you and others who have had some questions on
this subject of KumBoo which I had posted awhile back. Some
family problems have kept me occupied. But I’ll try to cover, as
best I can, some of the questions. However I am not an expert by
any means, and since learning the technique, and exploring the
directions given by the expert in this field, Prof. Komelia
Okim, I tried to push the envelope, in an effort to satisfy my
inquisitive nature.
I reasoned that if I could affect a “bond” between fine silver
and fine gold at a fairly low temperature obtainable with an
electric hotplate (@600 F), might I not also bond an alloy of
gold and silver(no Cu) to fine silver? If I did that, I would
have an applique of white gold which would not be affected by a
liver dip and have more than one color for contrast to a silver
background. I made a small ingot of 50/50 Au to Ag, milled it
down to @38G foil and attached a design(geometric) to SS base,
which had a fine silver layer using the same procedure taught to
me and it worked just fine!
From that initial success, I made other alloys, such as an18K
green gold, and others too. This is getting rather lengthy, and
I’m sure each of you can get the general idea. For the palladium
alloy I used 75% AU, 20% PA, and 05%Ag for a nice workable alloy
with the yellow bleached out.
The thickness I roll the metal to is 36g to 42g, and it goes
very fast even in a non motorized mill. Mill the ingot until the
rollers touch, make 2-3 more passes at this setting, and then I
use a sandwich of tracing paper and the metal to bring the
thickness down to gauge I want. Too thick and burnishing becomes
difficult to effect the intimacy of contact necessary for
bonding.
When metal becomes work hardened I anneal by placing the gold on
a sheet of steel @18-20g and heating from underneath with the
torch until steel turns red and this will anneal the gold
without risking melting.
For Rene Roberts
H&S suppied the palladium in sheet form
For Joan Dulla
I believe the 22K gold you tried had copper as part of the
alloy and I think this is what interferred with the bonding.
For Lisa
I don't know the answer to bonding to other metals, but I do
know that when using a steel burnishing tool, if it gets too
hot, the gold will stick to it and when rolling out the gold if
you use a sheet of clean copper to get the gold thinner in the
mill, the gold can stick to the copper sheet. (I guess cold
fusion)
I hope this has been helpful. Please feel free to e-mail direct
for further clarification.
JZD
