i have a kiln i bought from a jeweler in AZ about 2 years ago. i’ve
had to fix the electrical wires about a dozen times or so. now the
element is pretty much fried. i have no idea what i need. all i know
is my kiln draws 13.5amps 115volts and 1600watts. the element it self
is about 70-80" and the kiln is made by satellite manufacturing co.
Sean: Contaact Satilite Furnace Co and order new wiring for your
furnace and give them the model number ans size of your furnice and
they might send you the coiled element you need. Just pull out the
old element wires and replace it with the new. Yours Billy S. Bates
Satelite Mfg is in California. They have been around for a long long
time. Lonnie from Lonnie’s in Pheonix can help you call him. If in
case you are stuck I can help you by getting one for you. Before you
call get the model number if no tag measure the inner chamber size.
Kenneth Singh
i have a kiln i bought from a jeweler in AZ about 2 years ago. i've had to fix the electrical wires about a dozen times or so. now the element is pretty much fried. i have no idea what i need. all i know is my kiln draws 13.5amps 115volts and 1600watts. the element it self is about 70-80" and the kiln is made by satellite manufacturing co.
Do you know the wire size and diameter of the coil? If so we can get
the right elements for you.
Ken Kotoski
MPG Repair
www.mpgrepair.com
1-877-262-2185
