now..... where's...... that...... teaspoon." The pro chef goes
flip, bang, season, plate. Eat. It all comes with time.
One more time, John D. has it covered. One small thing he left out,
but I know he knows, is that when it takes you ten seconds to do
something that used to take ten minutes, it comes out much better.
The less time spent bending a piece of wire, the fewer the marks and
wiggles in it, the better it fits, the less time it takes to finish,
the better the finished product. Faster almost always means better
when something is done by a truly skilled craftsman. And speed comes
only from repetition. This is the main difference between work done
by a master and someone that is just good. The master has just done
it a thousand times to the average person’s one hundred and gets it
exactly right first time, every time - almost without paying
attention.
If you have ever watched a master goldsmith size a ring (which
contrary to popular belief is still a part of the job), you will
notice they don’t measure anything. They don’t have to. They just
know how much to cut out or add in and exactly the shape it needs to
be to fit perfectly. It will also be exactly right on, first time,
with no pits, thinning or lumps. The only times the master will
check the size is while rounding it up after soldering and five
minutes after starting when it’s finished and going back in the job
bag, and guess what. Both times, it will be exactly right. There are
no secrets or tricks, it only comes from sizing a thousand rings. Not
from anything else.
Making jewelry as art or as a hobby is different from doing it
commercially.
You aren’t constrained so much by time, which in my mind is a
detriment to learning the necessary skills. If anyone ever wants to
be a top-shelf commercial jeweler (in other words make more than
$50,000 / year at the bench) you just have to do menial tasks over
and over and over again until you can do them in your sleep (if you
do it long enough, you will be doing it in your sleep!) The new
term for it is “muscle memory”. Yeah, it can be boring at times, but
that’s where the challenge is, isn’t it? If it was easy, everyone
would be a master goldsmith and there wouldn’t be any money in it.
The only advice I can give to someone having a block of some sort is
to set it down, walk away, do something else for a little while and
then pick it back up. Even a ten minute break from a problem piece
will more often than not give you a little different perspective and
the thing that was giving you such a hard time will just go together.
Human beings learn things in spurts and plateaus and in the plateaus
sometimes we end up going backwards for a little while. There isn’t a
master of anything ever born that hasn’t dealt with this. This is a
major reason why masters become masters - they don’t give up when
they hit that wall. Helen, I’d be willing to bet you’ve just hit a
plateau. When you hit a plateau, you just have to work through it. It
might take a week or it might take a year. Eventually, you’ll get
through it and find your self spurting along again.
Just keep on plugging away at it.
Dave
