I will like to know if any member have experience or opinions about induction soldering, I was intrigued by a Stuller video showing an operator soldering a small four prong stone mount using an induction generator (Note that I am not talking about metal melting). I did tinkered a bit with a home made machine and managed to solder a ring and heat pieces and bits of metal to solder temperature. Browsing commercial and academic literature I found nothing about jewelry soldering. Thank you.
I found nothing on Stullerâs website by seaching on âinductionâ, âinduction solderingâ or âinduction generatorâ. Can you provide a link?
Neil A
The video on Youtube is titled "Stuller Die striking department " watch minute 1:15
interesting!
this looks like the induction setup
(coils heat) (i saw larger setups online for heating crucibles for melting metal)
this looks like a capacitive discharge welder (tack welder) set up�
julie
here is a bigger, crucible versionâŚ
Unrelated here. How come all models show women with beautiful fingernails freshly manicured? I never have my hands looking like that. broken chipped are mine, letâs not talk about the grime.
I bought a couple of HR Superior electric soldering machines a couple of years ago. Still working on the process. I am hopeful, as it seems to localize heat better than torch work. Supposed to work on anything from light prongs up to heavy shanks, depending on the setting. With heavy use, Iâll likely use a dedicated electrical supply circuit. I donât know if Iâd call this âinductionâ, but perhaps so. You attach a circuit to the item to we welded, then complete the circuit with a carbon electrode. Clean surface, and fluxing seems critical. When circuit completes properly, solder flows cleanly. Iâm kind of âold schoolâ, but then, my favorite car is a '63 Grand Prix. âŚ
