Leonard’s Aphorism (theorem):
Just because some never heard of it is irrelevant.
Just because it is difficult to use it is also irrelevant.
Just because some books says it contains zinc, does not make it
so.
Marlin’s corollary to Leonard’s Aphorism:
Just because Leonard says it is true, does not make it true.
I really like IT solder, not sure why. But there are problems with
it as well.
I became curious with the discussion on the composition, and thought
I would look it up in some of my references. I found only a few of my
books even mention IT solder.
Bruce Knuth’s "Jeweler’s Resource Pg 44: says “IT” is 80% Ag, 16% Cu
and 4% Zn, with a flow point of 809 degrees C. Hard solder is 75, 22,
3 at 787.
Oppi Untracht’s “Jewelry Concepts and Technology” pg 394 gives the
same composition and nearly the same flow points.
Mark Grimwade’s “Introduction to Precious Metals”, pg 95: lists
various solders, no “IT” but an “Enamelling” at 71, 22, 7 and melting
range of 730-800 degrees C. His hard solder is 80, 13, 7 at 745-778.
Harold O’Connor’s “The Jeweler’s Bench Reference” pgs 41 & 32 also
does not mention “IT” but has an enamelling solder, without Zinc, as
follows: Ag 6g (80%)and Cu 1.5g (20%) 800 degrees C and a hard solder
Ag 15g (71.4%) brass 6g (28.6%) 750 C.
None of these tables mention a silver/copper eutectic solder (Ag
72%, Cu 28%) by name (many other books did).
Where does that leave us? I think Beth Katz said it best: “It is who
manufactures the solder as to what is contained in the solder and
their formulation for that particular product”.
An interesting thing I found in looking through my enamelling books
is that none of them mentioned zinc free solder and many recommended
traditional hard solder, which all the recipes say contains zinc.
This does nit make it optimal necessarily, but it probably meant
that it worked for the author.
I know that there are literally thousands of formulas for silver
solder brazing filler material. If you look at the industrial uses
for silver solder, you will find a huge body of work.
Bottom line for me - I would choose a eutectic solder or, for a
higher melting point, a mixture richer in silver for enamelling if I
could specify my alloy. Most likely I can not, unless I make my own.
I am too lazy, so I will stick to my “IT” solder for now.
Marlin in sunny Denver
