Info on the Koil Kutter?
Hi Dave,
I’m enjoying the metal dowels I bought from you and am ready to
consider the koil kutter. Can you send me some about
it – description of how it works and price? Linda just sent me
an email and was raving about it.
Thanks in advance.
Rita
Rita- I bought a Koil Kutter from Dave and am very happy with it.
Coil the wire tightly and tape it with a layer of masking tape
before using the Kutter.
Rick
Richard D. Hamilton
wax carving, modelmaking, jewelry photography
http://www.rick-hamilton.com
@rick_hamilton
I’d like some info on the same. Thanks.
Sandi
http://www.angelfire.com/pa/bubblesbeads/index.html
Sundries for soapers gift baskets , BOTTLES & JARS
Some bottles perfect for beading!
LIFE IS GOOD! @Sandra_Good
Hi Rita,
Don’t worry about the ‘screw up’. Just think of it as free
advertising fo r the Koil Kutter (BG). I didn’t know you knew
Linda. Do you 2 belong to the same chainmakers or similar group?
Quite a coincidence, Two folks from NY & NJ who know each other,
meet the same guy in AZ on the net. Here’s a description & price
list of the some of th tools I make. If you have any questions,
just ask.
Thanks for the interest.
Dave
Koil Kutter $69.95 The Koil Kutter consists of an arbor on which
is mounted a 120 tooth, high speed steel, repaceable blade.
A guide-shield that attaches to a # 30 handpiece (any 1 in dia.
hndpc) or a Dremel. A coil holder that holds coils, up to 3 1/2
(85mm aprox) inches long & 1in (25mm aprox) wide.
There are 2 models, 1 for flexshafts & 1 for motor-tools. $69.95
each. Any model can be converted to the other by replacing the
guide-sheild, $14.95 The motor-tool model requires the use of a
1/8 in collet & a hex collet closer.
Replacement blades $9.95
Dremel hex collet closer w/wrench $10.95
Set of 23 mandrels & index, 2 -13mm, in 0.5mm steps. $29.95
Coil winder $19.95
An adjustable ring stretcher for making oval or oblong rings, of
uniform size, from soldere/fused round rings. $14.95
A corian draw plate for chain, 15 tapered holes, 3mm - 13mm.
$11.95
A solder aid to assist squeezing paste solder from tubes. $3.50
All tools come with a set of instructions & hints.
All of these tools resulted from student requests that arose in
a chainmaking class I teach.
All tools are shipped Priority Mail, unless you request some
other premium shipment. Shipping in the US adds $3.00 - $5.00
depending on the weight o f the item.
Payment can be Visa, Master Card, Discover Card, check or money
order.
Arizona residents add 5% sales tax. Items paid for by check are
shipped when the check clears. If you’d like to use a credit
card, e-mail me & I’ll give you my phone number so you won’t have
to put your card number on the net.
I don’t think it’s polite to do business on Orchid, if you’d
like more info I can be reached at: gemstones_etc@compuserve.com
