These are probably a hessonite derivative garnet with zircon
inclusions!!! Where did they originate from?, and if they are
african they will have an extremely high RI just by case in point …
If you can get your hands on the Encyclopedia of Colored Gemstones
by Joel Arem it will give you some solid pictures of the coloring of
these type of garnets if I remember correctly. Hope this helps…
inclusions!!!! Where did they originate from?, and if they are
... If you can get your hands on the Encyclopedia of Colored
Gemstones by Joel Arem it will give you some solid pictures of the
coloring of these type of garnets if I remember correctly. Hope
this helps...
DM, (whoever you are? ),
I thought of the high RI garnets but the highest I can find in any
of my references is African grossular, with an RI of 1.8. Since most
refractometers I know of go to 1.81 or so, they should have been
able to determine it. Of course the reason they could not may not
have been that the RI is beyond the scale but because the bead was
still on the string. That would make RI testing kinda difficult.
Anyhow, the originator said it was also pleochroic, which should
rule out garnet since garnet is SR. I did not think the several
colors shown in the photo were pleochroism anyhow, but looked more
like the colors you see in some lead crystal beads, which could
also have high RIs. I would have bet on glass except for the
inclusions.
I came across one description of these as "Vessonite (idocrase)
garnet’… so… I did a little further looking… and lo and behold…
idocrase aka vesuvianite is the exact color of the pictured bead!
