I have a high carat, thick, threaded earring post that needs an earnut. Is
there a way to make an earnut for it? There is no hope of trying to buy one
somewhere. Thanks!!!
Richard Laspada
Richard Laspada
Richard Laspada
tap and die set Richard. M.Gilger
Richard Laspada
Richard - I wish I could just draw it out for you, but we’ll try words.
First, imagine an ear nut “unrolled” as a flat piece of metal with a
bulge in the middle (like a snake who just ate a mouse). Next, saw a
piece of the appropriate karat metal into that shape. Then use a
threaded tap of the appropiate size to thread the center. You may need
to use a die to re-thread your existing post to match. Finally, roll
the edges up to form the back of the nut (or just fold it up like most
screw nuts). Happy threading, Mike
Mike, thank you for the picturesque illustration
s~~~~-:~ my rendition of snake with mouse inO
stomach. Sorry, It’s been a long day
Richard Laspada
Thanks
Richard Laspada
Richard Laspada
______ _____
I think that Mike means something like this: (_o)
bend -->/
You can buy taps and dies from good jewellers suppliers
If you lived a bit nearer than the other side of the world I’d be delighted to lend you mine!
/ / John Burgess
/ /__ johnb@ts.co.nz
(______)
______ _____
bend -->/
to lend you mine!
Ahhhhh, come on Mike, you can use the vacation
Thanks,
Richard Laspada
HI Richard
This most common way Ii’ve seen follows.
Saw (of if you have a disc punch…) a circular blank of an appropriate
size. The bend up a small strip of rolling stock (spring gold if you
have it) into the appropriate shape, maybe you’ve seen these handmade
earnuts, they’re common in Indian jewelry, also from Asia. Solder the
strip to the disc and drill a hole ever so slightly smaller than the
post size. The catch is you’ll need to find a hand tap that matches the
thread of the post. Once you find one, tap the treades into the nut, but
bear in mind that taps are very brittle and break instantly if they are
kept extremely straight.
Good luck on finding an appropriate tap. Gee, maybey you could make a
wax disc and force-screw the post into it, then cast that… it might
work… hmmmm
Richard Laspada
Handmade 18K and platinum gemstone jewelry. Fine die
and mold engraving. Diamond setting. Class rings/pins.
25 years experience in the jewelry trade. 515-472-9830
