genevieve hunt - the easiest method i use on flat surfaces is a small
piece of 800 grit paper stuck onto a 1" wide strip of foam core/
gatorboard with 3-m transfer tape - it also works for 3-d surfaces
if you use the corners: smooch a corner with a hammer - makes it
thin & flexible & pointy. i go diagonally in one direction & after
the entire surface is covered go the opposite direction & then use a
1500 piece to go either straight across or up & down - gives an
interesting dimensional finish that women like because it doesn’t
need the upkeep that mirror polishing requires. people, life is
complicated enough - simplify your work -
ive
