What you are planning WILL work, but is overkill and is a lot more
than I would do. My house is over 80 feet long with the fuse box on
the front end of the house. Wiring runs from the box to all the
outlets. I was very upset that the electrician ran 14 gauge wire to
all the outlets and only used 15 amp breakers. I was always taught
that outlets should be 12 gauge and 20 amp breakers so they can
handle things like the kiln. Point is that if you run, even an
extension cord if it is 12 gauge (can be $25 or more for 100 ft) it
will handle your load. The best way would be to get a spool of 100
ft 10 g four strand wire, and it can be the kind that can be buried,
then run it to your shed and split it into two circuits of 20 amp
breakers each. 15 amp circuits are for lighting only, if you want
outlets, use 20, even if code says that all you need is 15! Yes,
running it inside conduit will help protect is from any digging that
may be done in the area. Good luck and make beautiful enamel.
