OK - Ive done the research, phoned GP’s, friends in the medical
profesion, AID’s Hotlines and everything else.
The HIV virus will not last very long out of the body and
certainly not on an earwire. Alcohol is sifficient to kill it off
anyway -
Some other bacteria may last on earwires for a time. Hepatitis,
for example. This will also be killed off with alcohol or a strong
bacterioside such as dettol or listerine. -
Bleach is very effective. If you sell stones that are treated with
dye this may cause discoloration (“oiled” emeralds, dyed turquoise
etc.) -
A few, rare, weird bacteria may be able to survuve in pure alcohol
- but not for long.
5)Those medically qualified people who have written saying that
alcohp; is not a sufficient cleaner for surfaces are quite correct.
Alcohol evaporates rapidly from surfaces and will not be sufficient.
Dropping an earing into pure alcohol will be.
So the reccomendations I have form practicing theatre nurses,
surgeons and HIV experts is.
Drop the earing into a container of pure alcohol (rubbing alcohol
will do as long as it’s not adulterated with water.) -
Leave it there for 3 or four minutes
dry it using a clean, new tissue, discard the alcohol.
If you are using material that has been dyed you may find that the
alcohol dissolves the dye.
This is as informed an opinion as I can offer.
Tony
