Hello fellow Orchid members, I’m looking for a source for 14K yellow
gold stampings in the shape of a star. I really need small ones
about two to three millimeters in size. They can be thin, even 24ga.
would be fine. I could use larger ones as well. Thank you in
advance, Richard Olson, OlsonDesign Jewelers
There are star stampings in the Chain section of my Stuller’s
findings catalog. Sizes run from about 6 mm to 4 cm or so but if you
ask, they may have others.
You might try a paper punch with a star shape for the smallest ones
- they might just work on 24 or 26g sheet. Fancy paper punches are
usually available at office supply/stationery stores or craft
places.
HTH
Pam Chott
www.songofthephoenix.com
If you get a drawplate with star shaped holes, you can saw off as
many stars as you want in any thickness that you need. See
I didn’t check to see how many other suppliers there are …
Bruce
