Dear Friends, I need some hand holding. Plan to make a 14k solid gold
piece with a14k gold bezel that is 20mm x 7mm. How do you go about
soldering. I have worked in silver all these years and have done some
gold , but not a big piece. I have an acetylene tank—just straight
acetylene. Can the job be done with this tank? and what size smithtip
should I use?
I know that gold takes the direct heat for solder flow, but do you
still have to slightly heat the entire piece? Any help would be greatly
appreciated. Lisa
